Currently reading:
Connecting pvc pipes?
Discuss Connecting pvc pipes? in the USA Plumbers Advice area at PlumbersForums.net
After I cement my pvc pipe to its pvc connector, is it normal for there to be a small gap between the edge of the pipe and the indent in the connector? It's like 1/4" between the two. I mean, they are stuck and I can't pull them apart, but should it be better?
OK, thanks. Having a hard time getting it all the way in with the cement in place. Failed twice and that's with a quarter turn and all my weight on it pushing it into the cement floor. I'll keep trying.
Do you have a photo of said difficult pipe? Is there any excess solvent cement causing it to not go all the way?
Did you glue both the pipe and fitting eg not just the pipe ?
Need to glue about 3/4” up the pipe and 3/4” in the fitting twist and push at the same time to insert
Connecting PVC pipes is a fairly straightforward process that can be done with just a few tools and some basic knowledge. PVC pipes are commonly used for plumbing, irrigation, and other applications, and there are a variety of fittings available to make connections between pipes.
The first step in connecting PVC pipes is to measure and cut the pipes to the desired length. A hacksaw or PVC cutter can be used to cut the pipe to the appropriate length. It's important to make sure that the ends of the pipe are cut straight and even, as this will help ensure a good seal.
Next, the fittings should be chosen based on the application and the size of the pipes being connected. There are a variety of fittings available, including couplings, elbows, tees, and more. Make sure to choose fittings that are appropriate for the application and that are the correct size for the pipes being used.
To make the connection, start by applying a primer to the outside of the pipe and the inside of the fitting. The primer helps to clean and prepare the surface of the PVC, making it easier for the glue to adhere. Once the primer has dried, apply PVC glue to the outside of the pipe and the inside of the fitting, making sure to apply enough to cover the entire surface.
Insert the pipe into the fitting and twist it slightly to ensure a good bond. Hold the pipe and fitting together for a few seconds to allow the glue to set. Repeat this process for any additional connections that need to be made.
Finally, allow the glue to dry completely before using the pipes. This usually takes several hours, depending on the type of glue and the temperature and humidity of the environment. Once the glue is dry, the pipes should be securely connected and ready for use.
Reply to Connecting pvc pipes? in the USA Plumbers Advice area at PlumbersForums.net
