Discuss Connecting radiator with compression adaptor in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello everybody! Just a quick question and hopefully you would be able to help. I have 2 radiator pipes, coming out from plasterboard wall, those pipes was prepared to be connected to radiator, once it will be hanged. My question is: Is it acceptable to use compression elbow fittings chrome plated to connect radiator to that pipes, or its have to be copper soldered?
Thank you for your help.
Reply to Connecting radiator with compression adaptor in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
