Discuss Control panels in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gasmanrob
Can anyone recomend some good reading material regarding the above had a fault today that took way longer to solve then it should have. Not looking for anything too in depth just basic functional flow typical system set up and the operation of components. Just to get me familiar with it all.
thanks in advance GMR
Think he wants wholistic . GMR Lean what the pictorials on switches and control relays mean?
Ive got a pdf book of all popular controls and the wiring connections.
Seems quite recent.....well better than nowt anyway.
How do I share
Thisvone
A typical page.
And no..... I am not gratuitously just "upping" my post count :p
Although there are 289 more pages that would take me past 1k :p
All popular brands
Will email ermster
And try and add to dropbox
Cheers that all looks domestic though which I'm fine with.
problem today was a gas valve not getting power as it entered the plant room went to control panel did neon test and half the panel won't light up. Any way had power into the relay but not coming out only half the wires were numbered which made tracing it an bum! 24v contact not switching the relay over but by the time I'd had all the trunking out and followed the wire I'd lost nearly 45 minutes. Was after something that would give a semi common set up and as ermi rightly says just learning the relays interface ect.
Is there an emergency stop or old fire wire system still installed? Seen similar when the fire wire's not sitting right......
How do I share
I'd be happier for your own security if your dropbox link was kept in the Arms Phil.
Up to you if you're happy posting it here though matey.
If not the specifically then perhaps a decent guide and introduction into components?
Reply to Control panels in the Plumbing Jobs | The Job-board area at PlumbersForums.net
