Discuss Convert Mixer tap to Shower? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Need some advice. I have a mixer tap in the bath basin(see attached photo). I believe there are some ways of attaching a shower hose directly into the outlet thereby converting it into a shower. Firstly, is this possible on this tap and can anyone recommend me the best way for doing it- any good/ cheap connectors that will allow the conversion. I have seen this one however it seems rather dear-
https://www.amazon.co.uk/attach-Shower-mixers-kitchen-Measures/dp/B00JWMGK4W
Thanks.
You used to buy some a rubber attachment shower thing from woolworths a million years ago , bloody garbage.
A decent mixer tap with shower attachment would do , but you would be better buying a thermostatic one , far safer but will cost a lot more .
Looks a bit pants, basically slide it in when you want a shower. Hopefully it won't loosen off over time and slide out again in the middle of a shower if you catch the hose
What about this one, I changed our taps to mixer years ago. Fiddly pain in the arse with limited space under the bath but possible. Couple of quid more but proper mixer tap. Remember to change the hose to a 2m hose. They never supply one long enough to be useful if your taller than 5ft !!
https://www.amazon.co.uk/Trueshoppi...coding=UTF8&psc=1&refRID=V9KQ4E8DWKY2SJ5P5ZRS
Or the more expensive option but far better looking, and looks similiar like the one you have fitted
Modern Chrome Basin Mono Twin Basin Taps Bath Filler Bath Shower Mixer Tap Set | eBay
Or a waterfall mixer tap, which I hate but some think they look great for silly money
Square Waterfall Chrome Bath Shower Filler Basin Mixer Tap Modern Bathroom Set | eBay
Reply to Convert Mixer tap to Shower? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
