Discuss cooker hoses bayonet and micro in the Plumbing Jobs | The Job-board area at PlumbersForums.net
buckley plumb
i have been fitting both types of cooker hoses for years but never realy wondered untill today if there is any difference in the gas flow etc throught them.
Sometimes we just think the strangest of things! The other day I was thinking "I wonder if there's a limit to how many ants I could carry in one hand?" Obviously there is but visualised this big column of ants one on top of the other stretching high into the sky ..... hmmmmm!
Good luck in your quest buckley plumb :D I haven't got a clue :lol:
As gas compresses I dont think it would matter as long as the pressure was 20mb in both, but I can't be bothered thinking about it too much cause I'm lying at the pool in 38 degree heat in turkey, with beer in hand
Conventional are based on 12mm and micropoint is 10mm if you want to do a calculation.
Micropoint should be ok on anything up to a Range cooker, then I'd use a conventional hose personally.
Don't let the missus catch you chatting on that flippin forum again, especially on holiday!!!! :rofl:
Been a while now and still not really found if there is a big difference
On a stnd cooker no you won't find any difference
But on a big range you might find something
I've tended to fit a micro bore on a dual fuel as you are only supplying gas to the rings, if it's a gas oven or a range then I fit the larger type, never had any issues and not necessarily official advice, just a rule if thumb that works for me.
Reply to cooker hoses bayonet and micro in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
