Discuss Cost to fit a gas hob and kitchen sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Meady
Just wondering what you lot would charge to fit a gas hob, kitchen sink and connect the washing machine and dishwasher.
The hob is fitted into the worktop and the gas is allready there so it just needs the gas valve and connecting.
The sink will need making up and fitting to the worktop but all the pipework is ready in the sink unit to be connected on to. Plus the two machines, one of which will need extended hoses as both the machines are to the right of the sink unit so the standerd hoses won't do.
Cheers
I hope so because if it ain't then they will have to get the kitchen fitter back as I'm not cutting it out :)
a days rate,
why you fitting to gas valve?
you qualify for the plumbers arms where this is allowed to be discussed!.
you also have the required posts to join the gas section if you are qualified to work on gas!!
why not join one?
a days rate,
why not join one?
Who do I contact to do so?
Juat at a gas valve like so to isolate the hob if needed
http://m.NoLinkingToThis/p/gas-isolating-valve-15mm/46199
I would be £200. Remember the cheapest guy isn't assays the best quote.
Reply to Cost to fit a gas hob and kitchen sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
