Discuss Cross head tap removal.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
thereisawizza
afternoon all, anyone come across these taps? Need to change a cartridge and can’t work out how heads come off! Tried the obvious pulling etc, on a Belfast sink so can’t get to the back to fit new taps..... Cheers all
The bit under the handle with the grub screw, does that turn with the handle? If so, undo the grub screw and it will come off.
No grub screws! I think I might have to bite the bullet & drop the sink for new taps....
Wow word work is in a bit of a state, what are the hose pipes for ?
Are you sure that these have ceramic discs could be rubber washers, have you tried unscrewing the large chrome section
Reply to Cross head tap removal.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
