Discuss Custom basin waste fitting - what material to use in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
andrew2000
Hello,
Q - Which is better for a CUSTOM basin waste - PVC or Aluminium?
For 2 disabled colleagues I am considering a custom basin waste fitting (I am both Eng & Ergonomist).
Conventional solutions:
- Extends about 94mm below the basin, which even with a low height basin (115mm) only leaves a couple of inches leg clearance.
- Involves several fittings to knuckle bend & drop from 1-1/2" down to 3/4" hose barb re typical pumped application.
Alternative solution:
- Extends 45mm below the basin.
- Involves no extra fittings, has integral side outlet 3/4" hose barb.
CADing this out is trivial.
I have emailed WRAS (not a legal requirement, but may have some info) about what materials I can use.
- PVC is easy - and trivial to bond a hose barb into
- Delrin is easy - and a bit more involved re choice of adhesive
- Aluminium is easy
- Brass is expensive
For some reason I can not recall seeing aluminium in waste plumbing, only PVC (& ubiquitous ABS PP) and Brass.
Ironic only the USA has come up with a back outlet Inset "vanity" basin, that is from ADA beating someone with a hose... there is a large market globally for a few niche (read UK manufacturer could run off) basins. I remember the quality of Royal Doulton toilets... now there was a well made throne.
id use brass or stainless steel.
alu is probably not used due to reactions to soap and cleaning chemicals, maybe??
Yes, I think chemicals might be it re aluminium.
Brass is much cheaper to buy & machine than stainless. However I am warming to PVC as it is broadly used and this is not an application subject to high pressure, underground, UV exposure or high temperature (TMV).
Reply to Custom basin waste fitting - what material to use in the Plumbing Jobs | The Job-board area at PlumbersForums.net
