Discuss cylinder faulty in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stecod7
hi, had a few problem in january with blocked pipes from return flow from cylinder? with help from you guys i sorted problem. alas last week hot water started cutting out no hot pipes from return. heating side is fine. is it possible that coil has stopped working and is there any way i can tell if cylinder needs replacing, cylinder is 24yrs old. no dirty water is showing through taps. ive released any air and all pipes have been flushed. help wanted please....
has the hw zone or 3port mid position valve been checked to see if it's working correctly? Sounds very likely this will be the problem providing the cylinder returns blockage has been cleared correctly
hi thanks for reply. my system is gravity fed with no 3way valves, i chased every pipe from header tank to boiler when problem first started in january. uprouting floors etc. all electrics are working boiler is a floor potterton type. changed pump near cylinder and thats fine.
mostlikley to be air in the coil or the header tank ballvalve is frozen in the up position
Reply to cylinder faulty in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked overflow/expansion pipe. Hence the header tank then reaches the overflow level and the overflow trickles out. I have changed the ball valve washers thinking it was...
C
Hello I have a gravity fed system with a header tank in the loft, a water cylinder and a 3 way valve. The header tank in the loft is OK and has water in it. When the 3 way valve is in the mid setting the pump and pipes are quiet, and in the CH setting all is quiet. But when its in the HW...
Hi, I have two indirect water cylinders (Gledhill) connected to a gas boiler (Vaillant). The system is setup/programmed so that the tanks heat up twice a day for about 2 hours. When the tanks start to heat, one of them makes a loud vibrating noise, sometimes for about 15-20 mins, sometimes for...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the normal radiators get hot but two of the three towel heater/radiators don't get hot and the pipes feeding them are cool to the touch even after the boiler...
Hi, I’m having a problem with hw venting into the small header tank. This happens when it’s set to hw only or CH. I’ve tried lowering the water level in the header tank but it makes no difference. The incoming hot water is being taken back into system via the primary circuit 15mm supply so...
2K
