Discuss DAB Esybox Mini 3 in the USA area at PlumbersForums.net
All,
I'm trying to solve a water pressure issue and I'm not sure the best way to approach the situation.
I have 2 bathrooms:
  • A family bathroom being fed by the mains for cold & an unvented immersion cylinder for hot water
  • An ensuite with an electric shower that is fed by the mains.
The problem is if someone is using the electric ensuite shower and someone else either has a shower in the other bathroom, flushes the toilet, uses the taps or the washing machine draws water, the water pressure drops and the electric shower cuts out to prevent scalding as there is insufficient flow rate passing through the shower.
I want to fit a pump to boost the pressure to all outlets in the house and have been looking at the DAB Esybox Mini 3 as I like the idea of an all in one system and it can also be mounted to the wall easily as well as being quiet under operation. However as I understand it you should not fit these directly to the mains due to the maximum flow rate these pumps can provide. I don't really have the space for a break tank so was wondering whether it is possible to fit this pump and limit the flow rate within the menu system on the pump so it complies with regs or if I should be looking at another product?
Another option I've seen is the Stuart Turner Mainsboost Flomate MBF 12 which complies with the regs straight out of the box but the stuart turner website only really recommends these for a single bathroom where as I have two.
Is anyone able to offer advice on this scenario?
Cheers
Need to fit a break tank
also you shouldn’t have an unvented system if your pressure / flow is low / below spec
Can only boost direct mains to 12 lpm.
Need to look at static pressure, dynamic pressure and flow rate.
Also ask your water provider what they think they supply you.
I've done some more testing, there is a tap in the cupboard where the water enters the house and the meter is situated, I got 25+ litres per minute (there was no handle on the tap so I struggled to get it turned on to maximum quickly) out of that but only 4.2 litres per minute out of the bathroom and kitchen taps which leads me to believe the problem is not with the incoming supply.
Am I correct in thinking a mains pressure boost pump would provide little benefit if fitted in this case? Or would it still increase the flow rate out of the taps in the property?
Are there any other options available?
Wouldn’t do anything would go round every tap and measure the flow
Every tap in the house is getting a flow rate of roughly 4 litres per minute, the only one that is not is the tap in the garage in a cupboard next to the meter which I think may just be for testing (see attached picture). There's over 20 litres per min coming out of there.
Any chance of a picture further back ?
Reply to DAB Esybox Mini 3 in the USA area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
