Discuss Danfoss HPA2 Actuator Stuck in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi everyone, my first post here so go easy on me... 😄
I have Danfoss HPA2 motorised valves fitted to my heating system and one of them is giving me problems again. Typical as its the same one I replaced in December 2022. The heating never came on today so I checked the valve and the lever on the actuator and it was stuck solid. I removed the actuator and the valved turns easily, but the lever is still stuck solid. Is there a way to free up the mechanism within the actuator? I replaced this same actuator in December 2022 so a little disappointed it has given up already. Advice much appreciated, thank you!
You could try using some pliers but they do tend to either snap or seize
Reply to Danfoss HPA2 Actuator Stuck in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
