Hello all,
Customer has an old Megaflow, the type with a white top, and is complaining that she is getting less hot water than she used to, gradually. The property has 2 of these, the other one is located elsewhere, and is working fine.
The problem cylinder is located at the far end of the property, some way from the other, and most likely gets less use. All external controls are working just fine (indirect, both cylinders on same programmer channel but separately zoned) . The water, that there is of it, is plenty hot enough. Once it has been exhausted, recovery time is also decent. Primaries nice and hot. I haven't as yet measured exactly how much hot water is available , but have emptied the cylinder and inspected the inside and all is clear. I did this as there is also a direct cylinder on a separate system which got clogged up with scale a couple of years ago, causing a similar problem.
Any suggestions?
Many thanks,
Jezza
Any suggestions?
Many thanks,
Jezza
