Discuss Decommissioning cylinder coil on wet solar system in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
plumb_know
Hello Everyone,
I have customer with solar that doesn't seem to be working so only gets 1/2 a tank of hot water which is heated by the central heating system. She can't find a company to come out and service the wet solar system and she is looking at getting loft conversion in the future will likely get the solar removed.
She would like me to cap the solar coil going into the cylinder and pipe the bottom coil into the heating also so she can get a full tank of hot water, is it just a simple case of looping out the solar pipework before the coil?? I am concerned about the solar not having any source to dump its heat if it gets hot?? Also I know the solar has anti freeze in it, how much water should I get roughly from a system and what is the proper procedure to get rid of this water??
look forward to your replies
You should be able to loop the solar coil with the heating coil in parallel.
I would just drain the solar system and leave it open if not in use.
As for the anti-freeze, it would be food grade anti-freeze - not poisonous, so you should be able to dispose of the liquid down the sewer.
Done many systems where the boiler has been connected to the heating coil and solar coil in the tank - connected in parallel, without any detriment.
Thanks Oz, yeah I have bought solar compatible cylinders and piped them up twin coils in the past so customer has option of getting solar in future.
I was just concerned about disposing of the anti freeze and also whether it would be dangerous or have any ill affect on the solar panels not having any liquid in them
Thanks for your help
Reply to Decommissioning cylinder coil on wet solar system in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler. I may have solar panels in the future...
After some advice, i have recently had solar panels fitted and have an Eddi which uses the energy we generate to heat the cylinder using the...
Hello want to know on how do you calculate size of expansion tank for closed heating systems . for example 500 meters of 16mm underfloor heating...
We have a Megaflo CL210 Cyclinder along with Evohome hot water kit and have come across a problem. We have had solar installed and a Myenergi Eddi...
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages...
