Discuss Decorative TRV Caps? in the USA area at PlumbersForums.net
Does anyone know a good source for decorative chrome TRV replacement caps?
I'm slowly working my way through a property, putting all the rads on to a manifold system with local thermostats, manifold flow meters, adjustment for balancing and electrical actuators for each room. So the TRV heads now need to come off and be replaced by something just to acts as a decorative cap. Not the service cap type that closes the valve, but something that will leave it fully open without looking an eyesore. Replacing them with chrome lockshields is a non-starter, the old valves need to stay.
I know I've seen them somewhere, but can't for the life of me remember where? I imagine soemwehre like B&Q will ahve them but they'll cost a fortune for a bit of shiny plastic.
Change the trvs for lockshield only way im afraid also less chance of them leaking later on
As per original question - changing isn't an option. Not sure what the leak issue is, but there's more chance of a leak with a changed valve on old olives, I would have thought.
May I ask why it isn’t an option ?
Of course you may ask.
  • Reason 1 - I've got better things to do with my time than part drain as necessary and replace valves on 17 rads, even if I could get locksheilds to match the existing ones on the other side.
  • Reason 2 - Most of the valves are corner style, exiting from the wall and pipework is plastered in, also many are big & beefy column rads not your average Stelrad jobbie. Most are too tight to wall and rad to get an olive splitter in place. So replacing valves is not a five minute job (see reason 1) and my knees and back no longer need the hassle.
  • Reason 3 - Why shell out for a load of new chrome lockshields and risk new leaks (see reason 2) when a chrome cap will do the job?
[automerge]1582236424[/automerge]
Gasmk - yeah, thanks for the suggestion. I thought of that and it's the fallback option but if at all possible I'd prefer to make it look a bit crisper.
Good luck as to my knowledge they don’t make anything that looks nice only option is something like this but good luck as it might not fit as nothing’s standised
Hear you go these may fit if you have got time to order em 😂 kop
Reply to Decorative TRV Caps? in the USA area at PlumbersForums.net
