Discuss DHW secondary return pump - which do you recommend? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jim Goodenough
What is/are the best bronze/stainless steel DHW secondary return pump's on the market for largish domestic applications?
depends on budget
wilo
dab
grundfos etc
As above i have a 6year old system with wilo pumps fitted bronze and normal they are still going strong . kop
Reply to DHW secondary return pump - which do you recommend? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
