Discuss Diagnosing banging motor valve in the Oil and Solid Fuel Forum area at PlumbersForums.net
I have a three-zone 2016 house with gas heating. When the downstairs heating switches off, it bangs extremely loudly. I have tried adding clips and it only helps to a point, I would have to take down plasterboard to get at the noisest part. The valve appears to be the correct direction. I have a bypass, which seems to be working. I think the bypass pipe is about 15mm. I don't have any TRVs anywhere in the house. Do you think I might need a new valve or perhaps something like an automatic by pass? Thanks a lot.
If it’s previously worked fine, then something has failed, ergo you shouldn’t need to change piping etc.
Pressure looks a little low, had any issues with losing pressure, needing to top up more regularly?
Expansion vessel possibly lost charge/faulty?
Open the red wheel head 1/2 a turn the vertical one
Interesting. Is there a theoretical reason why an automatic bypass is needed and that gate valve is not enough?
The ABV method is more energy-efficient than the always-open gate valve. This is because the gate valve (permanent) bypass raises the return temperature, which adversely affects heat recovery by condensing boilers.
Hi, I figured out that there is a radiator in the upstairs zone (none noisy zone) with no TRV, which i guess acts as a by pass. I guess I will end up getting an ABV anyway, and just have two.
It seems the bypass pipe with the current gate valve is just 15mm so I called the boiler company (Ideal) to ask is this ok or should it be 22mm. Id replace it to 22mm if needed when. But ideal refuse to advise as I am not gas registered.
Reply to Diagnosing banging motor valve in the Oil and Solid Fuel Forum area at PlumbersForums.net
