Discuss Diagonal Heating Zones!! in the Plumbing Zone area at PlumbersForums.net
One of your heating eg rads is calling for heat eg it shouldn’t happen let’s say if you turn the stats down to 16 once the house is heated
but otherwise normal for the boiler to fire each and every time when heating is called for....so if you set the heating to come on for an hour if it fires up 10 times in that hour it's ok?
Yes as it’s keeping the internal temp to the lost heat
There are ways to control this better the TPone can operate in open therm , check with your electrical contractor I'm quite sure the Baxi assure is compatible also . Google open therm for a detailed guide of how it works and how best to use it . Kop
Heat only
Thanks could you rephrase that with red tank , white tank, left or right...about the level of my experience 😊 so I can point it out to them, thank you...
yes not a problem
White pipe coming out the floor plastic around 11/2 dia
3rd from the right going to the left
Hi Guys, they are coming to fix the diagonal heating zones tomorrow. Please could I have some more info in respect of the white pipe issue above. I attach a few more photos, it looks like 2 bits of plastic pipes stuck together one thinner than the other. Do these photos help you identify whether it is the correct type. Don't want to be fobbed off, so any technical phrases or standards that have been contravened would help. Thanks in advance.
If you lift up the carpet where it goes through you might be able to see how it’s joined below the floor eg elbow
If you see this (wrong) normally abs or pvc
This (correct ) normally polypropylene
Reply to Diagonal Heating Zones!! in the Plumbing Zone area at PlumbersForums.net
Afternoon Fellas If anyone has time to help with this snag it'd be much appreciated. We have a wet-floor system controlled by John Guest UH3 and...
Hi. A new house regulation for a 2 zone heating system because it's bigger that 150sqm. I'm I right in saying zone 1 should be all of the...
2K
A bit of clarification - I have extended a 3 bedroom semi detached and at the time central heating pipes were going in I told the plumber could I...
We have UFH throughout downstairs. I have had one coil replaced. I have had the thermostats checked that they are linking to the correct...
I have an older gas boiler HW heating system with a taco circulator pump for each zone that worked fine last season. When turning it on for the...
