Discuss Different CH zones at different temps in the Plumbing Zone area at PlumbersForums.net
dgrs
Dear All,
We're doing a remodel of our mid terraced house. After much agonising to do with low water pressure and flow, we're getting a Sundial S plan plus system with a conventional boiler.
The plan is to have thermaskirt on the downstairs on one heating zone, the standard rads on first and second floor (attic) bedrooms will be the second heating zone and then DHW will have its own zone.
Firstly, I'm amazed that it seems Honeywell do not do a 3 zone controller. They do 2 channel where one is for DHW and the other for CH, or one where there are two CH zones. To get what I want I think I need a Hortsmann H37.
But there's something I'm very confused about. Thermaskirt operates at a lower temperature (similar to UFH) than rads. With the above setup how is the lower temperature of that zone maintained? Thermaskirt offer their own programmable unit, so one option is using that for the downstairs then Honeywell setup for DHW and upstairs. Seems a shame not to have it all in one box. But this doesn't get around the issue of the temperature of the water. I understand that with UFH you'd have a manifold to get the right temp, and you can have a manifold with thermaskirt, but only for more complicated installations I thought.
Apologies if this is a stupid question but any help would be gratefully received.
Dave
if the thermaskirt works on low temp your going to need a mixing valve and a pump to achieve thisunless this is part of the unit it comes with
Reply to Different CH zones at different temps in the Plumbing Zone area at PlumbersForums.net
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
