Discuss Different Pipe Sizes in CH System in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've recently moved into a house and was surprised to see that some rads are connected with 15mm while others use 10mm, there is even one rad that has one of each. While I'm no stranger to CH systems and appreciate that di8fferent pipe sizes can be used to maintain flow and pressure, I've never come across a mixture like this before.
Its a 2 storey house and the system has 12 rads working off a Ferroli F30 combi boiler. The rads are what I would consider as fairly standard sizes for the type of house and the room size etc..
The system appears to work OK but it seems odd to be supplying reasonably large rads with such small bore pipes and having to step-up to 15mm to make the connections. Maybe some of you more experienced folk can put my mind at rest.
Cheers
Rambler
It appears to work OK but only with everything cranked up to near the max, with really cold weather I'm not sure it will be up to the job. I was wondering if the choice of such small pipes was perhaps restricting the flow to the rads and thereby limiting their performance. I appreciate that the boiler is not a world-beater and if its hampered by a less than efficient pipe system I may need to consider some major changes in the not too distant future.
Cheers
All it will do is reduce the KW each radiator is capable of producing
Installed correctly, 10mm copper will carry nearly 10,000 btu. That's quite a big rad! Unfortunatly, most microbore was thrown in.
Hi guys,
Thanks for the feedback. Most of the 10mm pipework in embedded in the walls behind the plasterboard so I can't confirm the quality of installation but I have my suspicions. We'll see how it performs if the weather gets colder.
Anyway thanks for your help.
Cheers
Reply to Different Pipe Sizes in CH System in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi thank you for letting me join this forum . We have an air to water heat pump but the bungalow is piped in micro bore 10mm pipe which doesn’t look well piped , kinky in pipes in some places ,some of the rad don’t heat up too well , probably because of the badly piped system, the pipe is all...
Hi All I'm planning on replacing a couple of rads soon as they are far too small for the size of the room causing the room to take an age to heat up but they are all connected via what I assume is Hep2O nothing is labled on the pipes that route behind the rad just on the flap behind the rad...
Hi, I'm studying plumbing and my work mate sized the opportunity to help him installing a new radiator. I'm looking for general advice which might eliminate mistakes. It'd also help me to build a portfolio before getting a job in trade. The house is old built and the rad goes into the kitchen...
G
HI folks, is it possible/feasible/reasonable to insatll an ufh manifold and system (for a 17m2 room) from a disused CH 15mm flow and return? I would install a 15 to 22mm reducer into a pump then a 2 port manifold then into the floor then. back into the return of the manifold. Its an old...
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a Worcester greenstar danesmoor 18/25 oil boiler. Covers 10 radiators mostly large double panels, some towel rails and smaller rads too, as well as an...
2K
