Discuss Directory? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Orry Clayton
Would it be possible, maybe in the the find a plumber forum to have a sub-forum "Directory". Where we all can post have one thread to post our details and then the thread automatically closed, but editable. Also if it possible, that the threads in the sub-forum could be shown in a random order, for fairness?
and no sticky's...
Not quite the same, I mean each member (users with 100+ posts) on here gets one post with their business details, thread instantly closed then displayed randomly. rather than a list which no-one looks at.
Nice thought. Bit impractical for the custard though if the members at the top at the time were thousands of miles away.......
Sub categories with areas north, south, east west, south west and croppie?
Reply to Directory? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
Hi all, I currently have an external water meter (which is a sub-meter) of my neighbours meter. The mains supply runs into their garden and then splits off into my sub-meter. We are planning on building an extension near to the existing external sub-meter and I have sought advice from Yorkshire...
I'm at the stage of my shower replacement where I have a new shower head to screw into the wall pipes. I tried it, turned on the shower, and find there are light leaks. Obviously I need to fix this so I got some Blue plumbers tape. Trouble is, the pipe doesn't stick out enough to easily wrap the...
In short: Do suppliers sometimes list BSPT as BSP? I need a tee, 22mm each end with a BSPT in the middle for an expansion vessel to dangle from. Why I think its I've used calipers on the threads and counted them, and the male end sticking out of the vessel is BSPT 3/4 with 14 threads per inch...
Hey all, Looking for some advice. My mother recently had her boiler changed but in the process the water had to be turned on and off as you would expect and the engineer broke of the handle. Luckily it seems you can close the valve with some pliers on the but I don't believe this is best for...
