Discuss Disappointed in hot water supply in the USA area at PlumbersForums.net
I had a new central heating system installed a year ago but whilst the radiators seem okay I am not happy with the hot water supply. I live in a bungalow so the boiler is on the same level as the radiators. When I turn on the hot water tap I have to run off what seems like at least a gallon of water before any warmth is felt. Is there an adjustment of any kind on the boiler (Greenstar CDi Classic) that can improve the system please?
thanks in anticipation
1. What sort of boiler did you have before? The CDi is a combi boiler so no hot water cylinder.
2. Did you have a hot water cylinder before?
3. How far is it from the boiler to the hot water outlet(s)
Almost certainly the wait for hot water is caused by:
a. The need to push out cooled water from the length of pipe connecting each hot outlet to the boiler.
b. Plus the time required for the boiler heat the water in the primary side of the secondary heat exchanger.
There is no boiler adjustment to reduce the wait time.
It’s normally to run off a bit of hot water due to that water in the pipe going cold since you last used the same tap
You could reduce the diameter of the hot water pipe between the boiler and your tap(s) to reduce the cold water content if this was not already done when the boiler was replaced?
From another angle, the benefits of this product are being massively overstated. But might also help solve your problem. Yet to fit one myself. They seem expensive, but, if they work...
:D they don’t work as you’ve still got the cold water in the line to remove
It’s exactly like a pre heat device just slows the water down until the water inside the boiler gets upto temp but you still have the leg to draw off
Reply to Disappointed in hot water supply in the USA area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
