Discuss Disconnecting Bidet in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
A simple procedure has turned difficult. I am trying to disconnect a floor-mounted bidet so I can change the click clack waste. All is straightforward apart from disconnecting the two flexible hoses to the mixer tap. I had expected the two isolators to make this easy but was unable to turn the nuts at their upper ends to release the flexible hoses. I now wonder whether the isolators are built in to the hoses. If that is the case, I would have to undo the compression joint on the (lower) mains supply side of the isolator which makes no sense. Obviously the water is turned off at the mains but inevitably some would get spilled onto the carpet etc.
I have attached a picture of the end of the flexible hose and the isolator. Any thoughts or advice appreciated.
You need to hold the body of the valve steady with, say, an adjustable spanner, put a spanner on the top nut and heave to undo it, while taking all the reaction force on the adjustable. Don't put the bottom joint or pipe under undue stress.
That's a separate valve and hose.
The built in ones don't have a nut, they're crimped like below,,
Thanks. Maybe the nuts are just extremely tight. I assume they do not have a left-hand thread - I’ve never seen one that does!?
It looks like they’ve run out of thread which can result in a tight metal/metal join where the nut hits the valve body - once you’ve cracked that joint I expect it to come undone easily.
To avoid this situation it is best to add an extra “shower hose” washer to the end of the flexi.
Thought I should post the outcome of this. I finally releases the two tight nuts at the end of the tap hoses. I had to use two huge spanner’s and even then it was far from easy. The whole of the first turn of the nut was very hard work.
There are black rubber washers in each tap hose but it does seem the nuts were more or less out of thread. When I reassemble it, should I use a fibre washer under the rubber one to gain a bit of thread?
Would recommend replacing the flexis and putting them on these so you will need one replacement valve eg
https://www.NoLinkingToThis/p/flomasta-isolating-valve-15mm-2-pack/65251
https://www.NoLinkingToThis/p/tesla...exible-tap-connectors-15mm-x-1-2-2-pack/2665r
OK, thanks for the good advice. However, what do you mean by needing one replacement valve?
You will need two nuts and olives for the compression side of the valve
Reply to Disconnecting Bidet in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all! I'm in the process of fitting a replacement undersink water heater in my shed and, as advised in the instructions (yes, I know, what am I...
Hi, one of the two hooks on my toilet Torbeck fill valve has broken, and so the float can't connect. I've bought a new fill valve, however it's...
Deleted member 120897
Are JG Speed fit fittings compatible with most 15mm plastic pipe? I want to swap out the tees and replace with JG Speedfit. Mainly because I'm...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
I am currently planning on replacing the siphon in the cistern and I am also considering whether I can add a hand bidet sprayer (similar to this:-...
2K
Aquarius
A
