Discuss Disconnecting Bidet in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Thanks again. The end of the tap hose remote from the tap, which connects with the isolator valve, is equipped with a nut and an internal rubber washer. Is that a problem? The sharp edge of the valve seems to cut into the washer.
Yes that’s the problem and that’s why the flexis need replacing now so you will need a new set of flexis and the kit I’ve linked above to stop it doing the same or some flat face isolation valves eg 1/2 x 15mm
Reply to Disconnecting Bidet in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all! I'm in the process of fitting a replacement undersink water heater in my shed and, as advised in the instructions (yes, I know, what am I...
Hi, one of the two hooks on my toilet Torbeck fill valve has broken, and so the float can't connect. I've bought a new fill valve, however it's...
Deleted member 120897
Are JG Speed fit fittings compatible with most 15mm plastic pipe? I want to swap out the tees and replace with JG Speedfit. Mainly because I'm...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
I am currently planning on replacing the siphon in the cistern and I am also considering whether I can add a hand bidet sprayer (similar to this:-...
2K
Aquarius
A
