Discuss Disconnecting dishwasher in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi guys. There's a small dishwasher in our kitchen. It's just a stand-alone one that you can put anywhere, rather than something built into the kitchen cabinets.
Anyway it's busted and I'd like to remove it and disconnect the rubber pipes at the back, but I don't want to do that and flood the kitchen the next time I put the washing machine on. At the moment it sits directly above the washing machine so I imagine they're on the same water network.
I suppose my question would be am I okay to just disconnect it as if it was a stereo system?
Cheers.
They can be plumbed in various ways but at a guess I'd say you may needs plastic cap to seal off the waste spigot and a 3/4 BSP cap to seal off the cold supply just incase thered a leak once turned off , a decent size old towel and a bowl to catch the crap out the waste hose , a picture would confirm this ?? . Kop
I'll attach picture now.
Reply to Disconnecting dishwasher in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi after some advice. I am buying a property - refurbished - they have put in a kitchen with space for a slimline dishwasher. There is sufficient...
I've got a countertop dishwasher. It's an RCA, but it's made in the same place as all the other brands, including Magic Chef, Danby, etc., that...
Easy if you're a plumber I guess, but if you have no plumbing knowledge? Its a Bosch, nearly ten years old I think, its door won't shut, so it...
Hi I wondered if it is possible to have pipework from a dishwasher running behind a built in, under counter, electric oven? I want the order of...
Hi, I have an issue with the standpipe trap in a 3-year-old flat. This flat came with a fitted dishwasher that has been completely unused for that...
