Discuss dishwasher and washing machine common pipework in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sparkspark
Hi, a conundrum for you.
Currently I have a washing machine which drains into a high level standpipe and trap, 32mm which goes about 2metres to an outside drain. Now, I want to add a dishwasher to this arrangement. Uprating the diameter of the pipework is the first obvious point. But can I get away with using another standpipe for the dishwasher, or could I use a spigot? There is no air break with a spigot plumbed direct in to pipework, like with the normal undersink arrangement.
On the one hand I don't want to overload the pipework if both appliances drain at once, but on the other hand, using spigots introduces the risk of potential siphoning. Would a non return flap valve in the spigot be adequate protection? And/ or an anti syphon device, ball bearing type? Any advice gratefully received.
Washing machine should be min 40 mm pipework as stated in part H building regs so to have the 2 into it I'd defo increase pipe size .
Best way is to run them separate. 1 1/2" waste for each. Of course you can use all those tapping's into the waste system, but they generally cause nothing but long term problems.
Reply to dishwasher and washing machine common pipework in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
