Discuss Do I need a expansion vessel fitted to my system in the Central Heating Forum area at PlumbersForums.net
Paul Jay
I have just had a water meter fitted and since been told I need a small expansion vessel fitted to my domestic hot water system as the meter will have a NRV in. I have also been told no I don't as my boiler is over 10meters away from the meter and any expansion will be taken up within the pipework, aproxx distance boiler is from meter is 20 meters. Boiler is a Worcester Greenstar Cdi combi. I would be grateful for any help with this question as i am now regretting having this meter fitted, Thanks.
It's in the WB installation instructions under 'Water Supply', e.g.:
"Where the mains water supply has a non-return, back flow prevention valve fitted, a mini expansion vessel (A) should be connected to the mains water inlet pipe (B) between the non-return valve (C) and the boiler (D) as shown opposite."
To reduce the potential for damage and leaks caused by overpressure, I suggest you don't use the 'pre-heat' function on the boiler until you have a mini EV installed.
Reply to Do I need a expansion vessel fitted to my system in the Central Heating Forum area at PlumbersForums.net
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
