Discuss Do i need to change washer in toilet cistern? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, my toilet keeps filling with water even after flushing has stopped. It did this about 3 or 4 years ago, and when I checked there was a tiny hole in the washer in the ballcock. I changed the washer and the problem was solved. I've checked the washer this time, but it looks perfect. Can't see a hole. Do you think the washer needs changing again, or could it be another problem? Thanks.
another problem!
more likely the dumpvalve seal if its the round type. or overfilling/flowing perhaps?
Flush the toilet and hold valve closed, if it still fills up then it is the inlet valve diaphragm (washer) if it doesn't fill up then the flush valve is letting by.
Thanks for the replies. I think it must be the flush valve as the diaphragm washer looks OK. I think I'm out of my depth now though, so time to call a plumber. Hope it's not too costly!
Reply to Do i need to change washer in toilet cistern? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I have to replace the flush valve and/or the washer but unfortunately it's inside the vanity unit. The only way is removing the toilet. I turned the screw on the cistern pipe to stop the water. I removed all the silicon around the toilet, now I can easily lift up the Front panel but...
Hello! I was checking something in the toilet cistern. I flushed, but holding the float ball, so the cistern wouldn't be filled. With a very low level of water in the cistern, I flushed a couple of times. Then I let go of the float ball and the cistern was filled. I didn't do or change...
My toilet flushes ok when the long flush button is pressed - but water continues to flow into the toilet bowl. No problems with the short flush. I have a Siamp Optima 50, the overflow funnel doesn’t seem to drop back down on the long flush. The short flush does all purposes but family members...
1K
Hi, I fix what I can around the house myself and have fixed a few toilets but I need help with this one. This toilet keeps running and stopping, running and stopping, etc. I've cleaned the rubber flapper itself and at the point that it contacts the reservoir, so I don't think it's leaking from...
Hey, I've got a leaking toilet and I need to replace the filling valve device which is a Geberit 810.L3 Type 340 with a 1/2" connector. Problem I've got is the connection under the tank (image attached). The top plastic nut (yellow) is only to hold the fill valve in place - I can undo it by...
