Discuss Doc m cistern what is the name for the lever mechanism in the Australia area at PlumbersForums.net
Inverness
Needing the lever mechanism but don’t know where to buy it from. Doc m armtage shank toilet
Toilet handle or toilet lever. I would advise purchasing a brass one, usually chrome finish as the cheap plastic ones often fail early. The arm that sits inside the cistern comes with the handle as part of the kit and the majority of them are adjustable so they will suit many different situations. Any plumber's merchant or DIY store will stock them.
Reply to Doc m cistern what is the name for the lever mechanism in the Australia area at PlumbersForums.net
J
Any advice as to how to install a Dudley concealed cistern toilet lever? The pack has three nuts but no instructions as to where they go.
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hello, First post, be gentle! Anyway, here's my issue. I have a Roca The Gap D-Trit close-couple toilet with integrated macerator in my secondary...
H
Hi, I need a Beta Cistern Washer for an old 1930's Armitage Shanks Toilet. Nobody has one. Can someone help. Or know anywhere that I might get...
Hi folks I’ve got a job today where I’m out in the middle of nowhere and the complaint is water passing into the toilet pan constantly. Now I...
