Discuss Downstairs rad won’t get hot in the Central Heating Forum area at PlumbersForums.net
I have 2 rads downstairs and boiler plus 13 rads on first floor upstairs. All work apart from the one downstairs, I have changed this rad and valves and bled all, still no joy, pipes are stone cold too. Think it’s on its own separate drop as other downstairs rad is hot.
Beginning to wonder if the pipes to this one have blockage and if a chemical flush would help?
Any suggestions appreciated.
Thanks for reply, do you mean open valves on rad one at a time and drain off whilst running system?
You need to close one valve and run the other whilst the system is hot. Then once it is hot water flowing, close it and repeat with the other. You can use a drain tap if it has one or disconnect each valve (into bucket) or disconnect the top plug and connect a hose.
If this is a sealed system you will need to ensure it doesn't drop the pressure whilst you do it or you'll give yourself other problems. If it is open vent you should be OK.
Doing this will pull any air through and prove there's no blockage. Once the water is hot both sides, re-connect and open both. If it doesn't work, I would be looking at balancing again (you said you'd tried it).
Pull water through each side one at a time until hot. Once that's done, re-open both sides and see if it made a difference.
Reply to Downstairs rad won’t get hot in the Central Heating Forum area at PlumbersForums.net
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
Evening all. I have an open vented C/H system with a heat only boiler and 10 rads over 3 floors. I checked the system mid summer and all was ok...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
I have had a problem where 2 downstair radiators are not heating up the same as the rest of the radiators around the house, now previously i had...
