Discuss Downstairs rads taking ages to heat in the USA area at PlumbersForums.net
Hi there I’m brand new to this forum and really need some help.
my downstairs radiators can take an age to heat up. Sometimes they just don’t heat up at all. Other times they do heat up and all is good. Until I turn the heating down at night and the issues begins again the next morning. A heating engineer has suggested a power flush. Any help/advice would be really appreciated.
Hi thanks for the reply.
move got the water tank type. Not a combi boiler. Sorry that’s as much as I know about the type of system. I do have a 3 way motorised zonal valve. The pump is definitely running.
What is confusing me is that then downstairs rads do warm up just never as hot as the up stairs ones and it’s a lottery as and when they heat up. As if this moment i have turned the heating off. Opened all rads to fully open. Then turned the heating on. Within minutes the upstair rads are proper hot. Nothing downstairs though
Could be the system needs balancing and would be my first approach.
Ive tried that many times unless I’m doing it wrong. I’ve opened the shield valves half a turn on the upstairs rads. They get roasting. Just now I’m I’ve closed them all up stairs to see if this does anything. Also just tried bleeding the downstairs rads. A steady flow of clean water comes out
Reply to Downstairs rads taking ages to heat in the USA area at PlumbersForums.net
I have had a problem where 2 downstair radiators are not heating up the same as the rest of the radiators around the house, now previously i had...
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
