Discuss Drainage for wetroom advice in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
mutley racers
Subscribed
Hi All
I am after a bit of advice, I am installing a wetroom in my house which is a bungalow. The vent pipe comes up through the concrete floor and up through the roof right next to the toilet pipe which is the same branch of drainage pipe.
Now the toilet long radius bend is
about 500mm to the bottom. My vent pipe connection in the concrete floor will be about 420mm. Would this be ok?
the pipe on the left is the vent where I want to take the elbow off and put a reducer to 40mm in for wet room tray. The pipe on the right is the toilet pipe which I am going to put the vent on there to vent the drain and then box the pipe in.
Thanks all
Keep well
Lee
I don't understand?
Hi Mate. Probably a bit long winded.
Basically the pipe on the left in the picture goes out through the wall and is the vent. The pipe to the right is my en-suite toilet waste. There is another toilet on the left which is connected to this branch which runs into the inspection chamber. What I want to do is take the elbow off of the vent in picture on the left and put a 110mm x 50mm connector on it for the shower waste. Then vent off of the top of the toilet on the right?
Any clearer
Yep that’s fine
Yep that’s fine
Great.
What I am getting at here is in Building doc H drainage it says that no branch pipe should be connected less than 450mm from the bottom of the long radius bend to the middle of the branch pipe? This is not a soil stack though so just thought I better make sure. It probably is just about 420mm I believe.
As you say that’s for foul
Reply to Drainage for wetroom advice in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
The soil pipe from my bathroom passes through the outside wall and into the roofspace above the adjacent single storey kitchen before dropping...
Hi all, I have an old toilet on the top floor (to be removed) which empties into an outdoor vertical SVP and into the ground. The pipe is...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
Hi all, grateful for your expertise on the following. DIYer, not pro. Rural property in France Single storey. Septic tank. Late 80s construction...
