Discuss Drayton Mid Position Activator MA1 always live? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plummit
My Drayton Mid Position Activator MA1 is working perfectly but I noticed that it is always warm to the touch even when the central heating and hot water is switched off and the pipes are cold. On removing the cover I find that the motor is quite warm and buzzes faintly. Should the motor be energised all of the time?
If its last point of call was heating then it will be in the heating only position and therefore the motor will be energized. If you turn the power off the motorized valve will return to hot water only therefore isolating the power to the motor when re-energized. Its nothing to worry about.
Reply to Drayton Mid Position Activator MA1 always live? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Hello Since moving into my property in 2016, I must have been through 5 or 6 mid position valves of various makes. I am just about to swap over...
1K
My 3 way actuator valve has gone on my central heating. I think it's a combination of the valve motor burning out due to a stiff valve on the...
1K
Hi, I had a Drayton ma1 mid position actuator recently installed as central heating had stopped working. Now my heating and hot water will not...
4K
Hi, My combi-boiler has just given up heating the house and basically only delivers hot water. While in central heating mode it heats up and stops...
Hi, I am abit stuck and cant really find a solution anywhere.. So, i have an F&E gravity system. The central heating pump needed replacing as the...
3K
