Discuss Drayton motorised valve in the DIY Plumbing Forum area at PlumbersForums.net
I'm needing to replace a Drayton Mid Position valve Actuator, code MA1. The failed one is 3-wire (red, green, black) but all the new ones I've found advertised are 5-wire (yet the cover data plates are identical!).
Question is - can I replace the 3-wire actuator with a 5-wire, and if so how should I wire it? Or are 3-wire versions available?
Thanks!
Are you sure the installer hasn’t just chopped the wires off
No, that's not the case, as can be seen in the photo...
3 wire is a diverter eg Drayton 27102
Pn 27652
Reply to Drayton motorised valve in the DIY Plumbing Forum area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
