Discuss dripping through tundish all the time in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Could somebody identify why cold water dripping through tundish all the time? My plumber told me the cold water expansion vessels installed wrongly. Please check the photos.
My plumber advise me to connect cold water expansion vessels on the bottom of pressure reducing valve. Please give me your valuable advise.
[DLMURL]https://www.youtube.com/watch?v=TyHM5Ox9Ixg[/DLMURL]
for a start you cant touch anything regarding an unvented cylinder and guess your plumbers not g3 reg best to get a g3 heating eng in
Good advice from Shaun. Dangerous things to mess about with. Who installed it
just needs someone who knows what they are about to check it is installed correctly, if it is they can then find and replace the faulty item causing the leak.
How old is your house?
You should have a certificate from gas safe for the boiler, this should have the cylinder notification on it too.
Get in touch with the installers and get the, to cone back and correct the fault.
Get a g3 in to look at it as previously advised. Although 3 years in I would say it's a safe bet you've never had it serviced.
Job 38.11
Reply to dripping through tundish all the time in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
