Discuss Dropped Zone from Heatmiser UH8-RF in the Plumbing Zone area at PlumbersForums.net
I have a Heatmiser UH8-RF controlling my underfloor heating, connected to the NeoHub with three zones with NeoStat v1 thermostats.
This is about 3 years old now and when setup everything was installed worked fine. All the main current functions work - I can control the UFH with the app and it works.
I rarely use one of the zones (utility room) but wanted to start using it but can't get it to work.
I've factory reset the utility room NeoStat and re-paired it in the app. The app pairs fine and the wireless/mesh indicator is lit. Everything looks fine and I'm able to control in the app and it shows on the NeoStat.
The problem is that the actions I take in the app or on the NeoStat isn't having any effect on the UFH. The zone light on the UH8-RF isn't lighting up and the zone is not coming on.
I've read the manuals for the UH8-RF, NeoHub and NeoStats and can't actually see how the actual assignment of NeoStats to physical zones takes place.
Any ideas?
After factory reset you need to pair your wirless Neo stat to a Uh8Rf.
Have a look in to Neo Stat manual for instruction how to connect thermostat to Uf8 Rf.
Thanks. I have factory reset and the NeoStat pairs with the UH8-RF (or claims to). When I trigger the NeoStat in person or via the app nothing happens on the UH8-RF - no lights or anything different.
How do I assign the NeoStat to a particular zone as they are just numbers in the wiring.
Reply to Dropped Zone from Heatmiser UH8-RF in the Plumbing Zone area at PlumbersForums.net
Afternoon Fellas If anyone has time to help with this snag it'd be much appreciated. We have a wet-floor system controlled by John Guest UH3 and...
A bit of clarification - I have extended a 3 bedroom semi detached and at the time central heating pipes were going in I told the plumber could I...
All. I hope you can help. I have an Intergas HRE 30 SB boiler (plus tank) which is driving a combination of (downstairs) UFH plus (upstairs)...
3K
Hi all, I have a Heatmiser UFH installation, 7-8 years old now. This week we noticed that a few of our heating zones were not warming up, even...
We currently have the ground floor wet UFH and upstairs rads running from an unvented condensing boiler. Any advice/experience on the following...
