Discuss Dry pressure testers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Matt0029
I have a monument dry pressure tester I occasionally use that has started leaking on the Schrader valve after about a month of using. Any one had a similar problem also I had to disconnect the air pump to get the Schrader valve to seal in the first place. Which made it hard to get to a round number on the gauge as you loss a bit of pressure by disconnecting the air pump from the Schrader valve.
should the Schrader valve of still sealed with the foot pump attached? Thanks I'll look at getting one.
I would release pressure from another point other than the valve. Yes it will leak if your foot pump attachment has a poor seal.
Reply to Dry pressure testers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In our sealed Megalo system, when hot water tap is used (say in bathroom shower) the megaflo is taking in some fresh water, I guess to compensate for the water used. The incoming water go via a pressure relief valve [most likely its this one: Heatrae Sadia 8 Bar Pressure Relief Valve -...
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with venting through the external wall and I'm reluctant to go with an electric boiler instead (because of the consumption cost)). It's a sealed system. The...
Hey, I've got a Grant Vortex that's leaking water from the seal around the expansion vessel - it's the round type about 50cm wide. The system is at 1.5 - 2 bar, but the expansion vessel has no air in it, and it's leaking water. No water is coming out of the Schrader valve either. The system...
1K
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed gas could be burned with a blue flame and the water was acidic (pH 5.5). Since then system has been chemically flushed (it was not too bad) and the...
Hello. I am a homeowner and have a Valliant EcoTech 835 (2017). Serviced every year and worked like a treat until about a few months ago when I notified the pressure reading was too high (> 3 bar). My plumber came and did a regular service and told me the boiler is in tip top condition. The...
