Discuss Dry run protection for DC Solar Pump sourcing water from a borehole in the Renewables area at PlumbersForums.net
We are installing solar power irrigation systems for smallholding farmers in Rural Ghana,
We have 12V DC 0.18kW (max 20A) pumps, there only power source will be a voltage varying from 15-20V coming from solar panels.
The boreholes are narrow, therefore is not much room for a float switch,
The max flow is 20 Litres per minute but more typical flows would be 5-10 liters a minute
Can anyone advise on flow or pressure switch solutions (I have done a google but I don't have experience in this area and am not confident myself)
Ideally, there would be no second power source or battery needed, and the solution should be as low-cost as possible. something under £20 per unit for 20 units would be ideal.
(It's a charity project replicating 20 units - so cost is important)
let me know if i missed out any key info
Could you use a manual On/Of switch in a panel or are you looking for something automatic.
Reply to Dry run protection for DC Solar Pump sourcing water from a borehole in the Renewables area at PlumbersForums.net
