Currently reading:
Easy question, broken coil?
Discuss Easy question, broken coil? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi all,
Got a quick one,
Sister in law has been told her coil in the cylinder has broken.
How can I prove this?
They don’t want to fork out for new cylinder unless they have to (they have had multiple faults on thier boiler which eventually got resolved)
Also, they had the cylinder drained and replaced the 3port valve a couple days ago, that’s when the overflow in loft started leaking, got a guy out who said the coil is gone...
So... how can I prove this?
Cheers
Edd
What sort of heating system have you?
Sealed system will drop in pressure.
Open vented system will have small feed & vent tank which will fill water in if higher than large cold tank
Cheers
Not sure what kind of engineer he was, assimehe is gas as was looking primarily at boiler in first instance. Yeah I have done a course, haven’t worked with cylinders much before though as I work in hospital maintenance (let the jokes begin!)
It’s a vented system, originally thought the best way may be to check the f and e level compared to the storage tank, however, if the 3pv is shut to the hot water, the tanks would level out. So surely need to test by opening the coil only, then checking out levels.
Just wondering for any quick and easy tips or obvious other faults it coulda been as not sure I trust this guy (came out 4 times before boiler was fixed) made a mint it’s the sister in law.
Pressure test would clear it up for sure tho.
Cheers
Edd
Is it the F&E that is overflowing ?
Does it do it all the time?
Where is the water coming from, if it is the E&F O/F?
Water finds its own level does it not? closing the 3PV on the flow doesn't stop it going back up the return!!
Should be able to work it out, without the need to pressure test it, but if the E&F is lower the the CWSC (which it should be) then draining the heating & disconnecting the the coil con's you should see the water leaking out.
We once went out for a meal with our neighbours. I sat next to Julie the neighbours wife. All through the meal I could smell plumbing and thought it was me, so asked wife later did I smell, answer no. So next day called round to tell Julies husband that their cylinder had a broken coil and Julie was bathing in central heating water and stank. He made a story up
and I replaced the cylinder
happy days. centralheatking
Now that is my kind of girl !!! ;)
Hahaha I've heard it all now.
Reply to Easy question, broken coil? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
