Discuss Electric radiators or electric heater for hydronic radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I am looking for some advice please.
i have a holiday lodge that has an electric water heater to heat water that is then pumped around the central heating system that consists of 7 radiators. I need to get it totally replumbed as I have removed all the pipe work due to it all being surface mounted. So I have to put some money into it. I have recently seen the Fischer electric radiators and I am wondering if they would be more efficient than the existing system.
Is it more economical to use electricity to heat water that is then pumped round a building with the subsequent losses of heat or is it more economical to use the electricity to heat the rooms directly?
would love to hear opinions or better still experiences.
thanks
al
Reply to Electric radiators or electric heater for hydronic radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
I reckon if I did a survey of 100 heating engineers, asking what would they recommend for heating a granny annexe being built onto the side of my house, in place of the garage, most would give me a suggestion to put in a) an extension to the existing boiler rad circuit & electric water heaters...
eco-heating options
E
Hello all, I live in a flat that has communal heating through a single pipe system. I recently had replaced a deco flat panel (waffle) radiator with a more mundane type 22 panel radiator. The problem is that the new radiator sort of worked in the beginning, but it does not emit any heat now...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the normal radiators get hot but two of the three towel heater/radiators don't get hot and the pipes feeding them are cool to the touch even after the boiler...
Morning all, Can a towel rail thats been converted to Duel fuel trip the boiler RDC. We have just had a new radiator fitted and it's heated by heating system and a heat element via T-piece. we only have the electric element turned on with both valves open if the electric element is on can...
asked to specify for very small studio flat, architect has drawn a combi boiler, 2 radiators, heated towel rail and shower, basin, kitchen sink, washing machine. seems overkill to me, in the past i have used electric shower, 15l 3kw Ariston for hot water, and electric panel heaters, but he is...
