Discuss Electric shower problem in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Okay thanks, own mains feed how do you mean?It sounds like your shower might not be getting enough water due to the way it's connected. When teeing off a toilet's cold feed, you might not get enough flow for a good shower. First, check if there's any blockage in the pipes or shower head that's reducing flow. Also, ensure the pipe size to the shower is adequate; a too-small pipe can restrict water flow. If possible, consider running a dedicated line from the mains to the shower. This could improve pressure and flow significantly.
What size piping and length is the feed to the CWS?, what is the make/model of the shower.?Okay thanks, own mains feed how do you mean?
I was going to tee off the feed to the cws tank but that would be the same outcome wouldn't it, as its a shared feed with cws tank.
15mmWhat size piping and length is the feed to the CWS?, what is the make/model of the shower.?
Yes toilet shuts off when the mains stop tap is turned off.Other than that try the usual, remove the shower head and see how the shower runs.
Remove the hose altogether and see how it runs.
Check the inlet filter.
Check any valves are fully open.
Reply to Electric shower problem in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
