Discuss Elson Coral E - No hot water from overnight immersion heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
charlie_p
I recently bought a 2 bed flat fitted with a Elson Coral E thermal store unit, and unfortunately it's not generating any hot water from the over night immersion heater. The water isn't as cold as the cold water tap, but it's also not anywhere near lukewarm let alone hot. Also worth noting, the pipe to the left of the blending valve isn't hot to the touch.
The additional boost immersion heater and manages to output some hot water before turning luke warm after a min or two. I've tried turning the blending vavle though this hasn't made a difference.
Can anyone recommend a company/individual that has exposure to this type of unit in the SW London area?
Many Thanks,
Charlie
Do not alter the blender untill the cylinder is that hot you cant touch the drain off cock after it has come off its off peak tariff. Is the bottom immersion powered of a switch ? Or a programmer ? Its probably just a faulty stat .
Guess its either timer/programmer or as said immersion heater thermostat
Check the overheat cut out on the bottom element (press the button).
Apart from that any half decent plumber should be able to sort you out. There is nothing complicated about fixing them.
Reply to Elson Coral E - No hot water from overnight immersion heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my bathroom, and according to the plumber who fitted the new taps, high-pressure taps were fitted. Consequently, the water from taps is of a low volume...
hello we have an unvented system. we have an issue where the hot water is hot for 10 seconds and then luke warm, turn off taps / wait and turn back and it repeats itself. had boiler checked and told it was the expansion vessel. Had the expansion vessel drained and recharged. plumber told me...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that heats on controlled load over night. The large tank is in roof space of 60s built villa unit. Every few mornings, no hot water will come out of...
E
Good evening everyone :), I’ve recently moved into a new flat that is completely electric (It’s got a dual immersion heater) and just had a smart meter installed. The dual immersion heater and has two separate switches - one is labelled top. I’ve had them both on since moving in but just seen...
1K
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
