Discuss End cap or compression stop end or end cap? in the USA area at PlumbersForums.net
Hi
I need to remove a pipe that ran to an american fridge as the previous owner decided cut and clamp it as opposed to cap the pipe under sink, do i use an end cap or compression stop end?
Just posting again with a picture as i cant seem to edit my post, looking to remove a pipe that went to american style fridge. The pipe too right went to fridge which what I want to remove.
Replace the compression tee piece with a compression elbow. You could also get away with using a blanking disk in the redundant branch of the tee. You use the original nut to hold the blanking disk in place.
Reply to End cap or compression stop end or end cap? in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper...
