Discuss EPH 2 port valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
nowucit
Morning guys,
fitted two of the above yesterday without fuss until I refitted the actuators, then noticed that one of the manual override switch doesn't fully return to auto position when released from manual, works perfectly fine when not fitted to the valve body. Swapped them around and tried it on both valve bodies with same issue appears to be working fine except for approx 1/4 inch of slack/movement in the lever.
Has anyone experienced anything similar ... Basically I'm trying to decide if the actuator is nackered.
cheers
Reply to EPH 2 port valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
