Discuss EPH V222D 2 port valve vertical installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
nowucit
Evening guys hope your well ... Does anyone know if there is an issue installing the above on vertical pipework? Instructions only mention horizontal installation which has thrown me a bit, would not have thought there would be an issue but thought I'd check with you guys.
cheers
cheers
As long as motor won't get wet if shaft weeps go for it. Bit like a pump... Don't want electrical box under pump .
Reply to EPH V222D 2 port valve vertical installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
