Discuss Equivalent part number for NewLec immersion heater NL27PT in the USA area at PlumbersForums.net
Thanks for the information, so this reading is across the heating element. Do I have to undo the connection before measuring? Also, do have to test the thermostat connection as that might have blown and what reading should I get.3kw immersion element should read 18-20 ohms across the two terminals.
Thanks and that what I thought. I got confused when I spoke with NewLec technical engineer. They said that the equivalent element number is 1051043918 which is only 18". Thanks, I will first check the element with an ohmmeter and then order accordingly. Electric will be switched at the mains box.Looking at the code I’d say it’s 27” so any thermostat form one that length would suffice, if whole element, then again any 27” should work. Bengee has given you the resistance readings.
Thanks and I will fully isolate at the main consumer box even though I have a separate fuse for the immersion heater.WHATEVER you do, before you check it, make sure it is fully isolated at the main switch, preferably at the consumer unit unless you know for sure the immersion isolating switch is double pole.
Reply to Equivalent part number for NewLec immersion heater NL27PT in the USA area at PlumbersForums.net
