Discuss Error A03 Overheating despite of all sensors are OK in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jarek
ARISTON ACO 27 MFFI with the boiler.
I have Error A03 Overheating 105 deg despite of all sensors are OK.
I have checked all NTC (1,2,3), connectors, parameters and there is no problem.
The ACO 27 starts pump and ventilation. On the cnob I can set temperature central and domestic.
When I press 10s RESET and MENU button there is monitored value 20deg on NTC1, 19deg on NTC2, and 21deg on NTC3 (boiler).
Where is problem ? What can I do ?
Jarek
You can stop messing around with something you don't understand and get someone in who does.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. http://www.ukplumbersforums.co.uk/im...-gas-engineer/
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competetence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to Error A03 Overheating despite of all sensors are OK in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
