Discuss Excellent pipe bending skills in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Definitely neat but slightly disappointed of the installer ... being lazy and not using pipe clips. He could have also cleaned the pipe a little ...
It's like the version of the passover a friend of mine came across. Two pipes at right angles on a collision course. Both hammered flat to 7.5mm thickness. Much more effective than pulling a conventional passover.
That's a brilliant idea.
I can't fathom why I have never thought of doing that.
Reply to Excellent pipe bending skills in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I will need: install new 100mm pvc pipe work, 90-degree bend for new W/C install new 100mm pvc pipe work, 90-degree bend with new gully pot at...
Years ago I installed a Miral excel 1990's thermostatic mixer. It was an ugly thing compared to todays standards, but it had the advantage of the...
I’ve just swapped these new valves over live. Didn’t realise how bad the old nuts looked until finished the job. Would it be hard taking these...
Choosing the right pipes for your home is a critical decision that impacts the longevity and efficiency of your plumbing system. In this...
Where can i buy a replacement Harvey G1240 Riser pipe for my Harvey water softener It has a small hole right on the bend is there is a fine mist...
