Discuss Expansion Vessel for a Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Guys,
My expansion vessel has burst..
What is an average size I should be looking for in an expansion vessel for my heat only boiler, and are there any good brands I should go for?
Thanks!
How many rads ? And where's the expansion vessel located ?
no outside, it's a heat only boiler..
A 12 l should do you fine altecnic do some very good expansion vessel and filling loop kits
Reply to Expansion Vessel for a Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one ....just easy to use and reliable. The fluke 115 looks good but its above my budget. My current socket and see one was great but it's developed a fault.
