Discuss Expansion Vessel Hose Change in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hi
How simple is it to replace the expansion vessel hose? Do I simply turn the boiler off, drain the boiler and swap hoses, using some PTFE tape?
Reply to Expansion Vessel Hose Change in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
