Discuss Expansion vessel - not ugly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
Looking for a small additional expansion vessel for a heating system to go next to a combi as there are a few big column rads in the house.
Ideally not something ugly :confused: so the standard red type is out.
I have seen some online pictures of a compact almost like a squashed football but no idea of the brand.
Any ideas?
Any ideas?
Thought they had to be red for the heating circuit?
Not as far as I know, I have fitted other colours that are for heating
It's more I need something that I can fit neatly above the boiler
Have a look at imi heating
That's the little beauty
Looks familiar...
EDIT - Though this is actually a CWSC I had to leave in place as it doubled as the flush cistern for the toilet on the floor below, via a valve on the flush pipe. At least now it only feeds the WC.
Who installed the cylinder?
I installed the cylinder. The Feed Cistern was separate from the CWSC shown and I did fit a new Combined Feed and Cold Water Storage cistern in the loft. The cistern shown does not, and never has, fed a cylinder.
However, as I understand that a flush valve operated WC is no longer permitted to be installed in domestic settings (if, indeed it ever was), I felt the best course of action was to leave that installation as it was and so nothing on the WC side has been changed.
NB - THE SPEEDFIT TO COIL WAS TEMPORARY, TO ALLOW HOT WATER OVERNIGHT IN PREPARATION FOR A DEDICATED CIRCUIT TO THE DHW CYLINDER! Don't want you to think I'd be happy leaving it like that :)
What would you have done?
I see thought someone had changed the cylinder and left the feed the same
God no. This was the feed cistern:
The pipe elbow on the left is the vent, the pipe insulated and covered in string is the gravity feed from a home-made solar panel running direct into the feed cistern, and the ballcock is over on the far side where there is literally no access. (As I said, how on earth do you expect me to service that ballcock when I can't so much as touch it with an extended arm?) Amazingly, there is actually a lid (moved further to the right when I took this picture), but it has a slot cut in it for some obscure reason.
I replaced the cylinder and cistern and commented that the bathroom pipework was restrictive but we'd try leaving that for now: the hot water flow increased from 6l/min to 14l/m at the bath tap and the customer said that was more than good enough for her, plus the water actually gets hot now!
Old school soldered patch as well :)
Reply to Expansion vessel - not ugly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
